I feel that the clutch of my diesel Brera is too soft, ie it disengages at the very end, when the pedal is almost at the floor. I suspect that the clutch needs bleeding, but I cannot find the slave cylinder. Any suggestions?
Jesmond
It is inside the gearbox bell housing and it's installed around the gearbox input shaft, however you will see the bleed nipple pointing out from the bell housing follow the rubber hose going into the housing
