Hi guys. The left side turn signal light on our Giulietta has stopped working. Can I change the light myself or do I need to go to a repair shop? Thanks in advance.
Having done dip beams on mine and judging by picture indicator is below dip beam access I would say you need to remove bumper and then the light assembly.
It was a ball ache getting at the dips as access is tight found it easier taking Kano out. Indicator looks even tighter to get at!
Thank for your help, but maybe I haven’t explained it correctly. It’s the side LED turning light which is placed in the front left fender and not the one in the main headlight?
Ah; as Johnny says that’s an easy one. You can see the clips when the bonnet is open. Possibly the only lamp that can be changed without removing skin from knuckles.
