1 - 13 of 13 Posts
Well looks like my car has come up to its second "mid life" crisis, there's a whole load of stuff that needs to be done
1. Both Front Lower Wishbones
2. Drivers side upper wishbone (the passenger side is on it's way out)
3. Drivers side inner and outer CV joints (passenger side is on it's way out)
4. Cambelt due within 6 months
Obviously the most cost effective thing to do would be to fix them and keep the car but I fancy a change
With 180,000 miles on the clock and with these "issues" I probably can't expect to get much more that £850 (maybe not even that)
How much do you think I'd get from stipping it?
GTA Seats (and door cards etc) £350?
8C style alloys (2 perfect, 2 kerbed) all with new(ish) tyres £250?
Injectors £100 each?
Gearbox with Q2 £300?
Remapped ECU £100?
I'm just wondering if it's worth the hassle...
seems a shame as it looks tidy. Spares will get you more but will leave you with a lump for a while.
Ill take your alloys if you decide to sell, what size are they?
Fix the issues they are only small.
Cambelt you can then price accordingly.
Makes more financial sense that way.
id say fix and if you feel its break worthy, just run it till the cambelt snaps? which it probably wont for ages, the jtd belts tend to go well beyond there interval unlike the twinsparks.
The pictures look quite good, but if you look even closely at the bodywork it looks quite shabby now
If you sell is it as your discription below your photos
Just might be interested as a project
Looking on autotrader even "immaculate" ones only go for about £1500, so don't know how much I'd get for a project
I do know it makes more financial sense, but I think I just fancy getting a new car, and now would be the best time, if I fix these issues then I'll want to keep it for another few years
+1 H ave to admit if it was mine I would fix it first :thumbs:
I've had 156s for the best part of 10 years ... perhaps time for a chnage
The trouble is the issues above have to be fixed in order to pass the MOT, also I suspect that the clutch must go soon (it's still on the original) ...
Break it. Basically, it's worn out and at the end of it's life.
What a few suspension niggles make the car end of life.
I think the crux of the above is not that they are difficult jobs just that the Op would like a change more than anything. If I was in the market for a 156 I'd snap it up. Unfortuantly it would mean me sellnig my 147 and I just can not be that bothered to do so.
As a project though I'd easily take it on. But I'd probably ruin the 2.4 as I do 90% town driving and a big diesel like that is better suited to motorway slogs.
But the spec on the car is pretty fantastic even if the body work may be shabby.
I'm sure if the op didn't fancy a change those small issues would be fixed and used for another 2 years.
It'll make someone a good cheap fast motor if they are willing for a small amount of work.
thats nonsence IMHO
that car deserves to go to another car lover if you fancy a change mate - you would get more money from the parts i know, but more hassle - and the car deserves to live on i think.
i would defo have the wheels if you were selling
What will happen to carputer? :cry:
Read Only
Which of the issues have to be fixed to get an MOT? As far as I know, as long as the gaiter is good, the joints can be in truly terrible condition and still get a pass.
If you are doing it yourself, then fix the wishbones (easy job) and while you are at it, the driveshafts are pretty exposed at that point.
You then have a few hundred additional quid in it, but you can carry on driving it for the next few months while you find something else. Though you should note, if the wishbones have failed the MOT, the handling will be absolutely transformed when you fix it - you may decide you like the car again.
If you then want to sell it, you are flogging a car with most of a year's ticket and in need of a cambelt. That is a pretty easy sell. Breaking is hard - unless you live on a farm or similar where you can leave a wheel less car for a few months....
The car is absolutely fine, they are standard wear and tear items, nothing majorly wrong
You're absolutely correct if I didn't fancy a change then this wouldn't have even been brought up ...
There's about £1k worth of computer equipment in the car, whatever happens I would take this out as a condition of the sale (to fit to my next car!! :thumbs:)
I should update my progress thread as I've made loads of improvements to it over the last couple of years
The gaiters are pretty much screwed (have started leaking) so they will almost certainly fail, there is also a reasonable amount of movement on the suspension which is also a fail, the MOT runs out in Late Aug/Sep so I've got until then to make up my mind what I'm going to do.
I could do the work myself, but tbh I can't be bothered, every bolt on the entire car is always rusty to hell and a PITA to remove
1 - 13 of 13 Posts
