1 - 9 of 9 Posts
hi im dave and new to this site.
i have a problem with my 156 selespeed, as soon as i pull up in traffic or at lights etc, the gearbox goes straight into neutral then sometimes it takes several time to get into 1st gear.
i recently had a new clutch and engine fitted. it was also taken to a dealer to be programmed, everything was ok for a month then this problem occured, it was then taken back to dealer who could not find the cause, nothing showed on ecu.
i would be grateful of any advice
thank you
and check your battery !
Does it always happen, with engine hot or cold? How far do you go before it starts to play up?
Common causes: clutch plunger length incorrect, accumulator faulty.
Think I'd be looking at the gearbox speed sensor...either a dirty connection, or a faulty sensor.
If you remove the sensor, and the end shows signs of wear, it's an indication that the gearbox casing or shaft bearing is not very well.
1 - 9 of 9 Posts
