1 - 9 of 9 Posts
can anyone tell me the voltage i should have at the socket for my selespeed pump when the drivers door is opened
Should be the same at the battery voltage.
ie somewhere between 12.5v & 13v
thanks for that,its a continuation of my pump not priming took it to my local fiat they said the pump was faulty and the actuater was leaking,id checked the oil throughout the fault and had no oil loss he said the tank was nearly empty and i was charged for sele oil, on fitting a new pump yesterday myself i noticed he had filled the oil tank to the brim not the max line ***.im only getting 6v when the drivers door is opened so on advice im checking the door switch and checking the relay again as the new pump has made no difference.
the relay costs 5 euro, so you have paid a kingsransom for parts that are not faulty :mad:
thanks for pointing that out!!! i will make a claim against the garage who were asked to check the voltage as i thought all along it was electrical not mechanical...those pesky stealers.
I have a couple of them, but I am in Holland... could send one
Banned
You can come over and I'll try my spare one in there for you, but you can't have it, I need it for diagnosis purposes.
you can test it yourself, just swap it with the one for the fan (located in the relay box in front of the battery)
HTH
1 - 9 of 9 Posts
