I have a registered version of Fiat ECU Scan and know that the selector rod length should be 28mm. Can some please advise which parameter in Fiat ECU Scan gives the selector rod length.
thanks
try alfadiag, on the sele it is more precise (my 2cents), download from ALADIAG.NET
Thanks rarebear. But which parameter shows the selector rod length in Fiat ECU Scan and for that matter Alfa Diag?
I use it all the time but usually just see it and adjust! Ive feeling its something like clutch pressure travel or similar.Its not hard to figure out cos click on them all and one should be within the right figure then adjust the pushrod length and see what figure changes when viewed on your laptop.
Clutch Rod Travel and after seeing both pieces of software in action I would say that FES is far superior and more accurate than Alfadiag, it doesn't drop out or crash and is fully supported with a forum of its own. AND IT IS CHEAPER.
I think it depends on the car and the interface ... AlfaDiag is better on mine, FES drops too often.
