1 - 20 of 28 Posts
I had another selespeed pump fitted as unble to go into gear was stuck in neutral, Worked fine for an hour, now no priming when opening doors and stuck back in neutral, any ideas please help
Hope you get it sorted soon then sorry could not be of more help but they are a bit of an experts job and can be a little temperamental good luck I keep watching see if you get any joy
:thumbs:
Did you fit a new relay as well?
And check the fuse !!!
Rarebear have one of your OBD cables but dont have the software for it anymore any ideas where to get it from,
Dose the alfa diag site still work??????????
Alfadiag is obsolete andremoved from the internet, multiecuscan is ok,
Multiecuscan.net
Try to put 12v direct on the pump ....
....forgot to tell, selespeeds need a strong battery !!!
David ! thanks
Discussion Starter #18
Hi mate got into the ecu 2 fault codes p1763 CAN message
p1752 pump relay high.
Battery was reading 11.69 volts according to mutiscan Will get a new battery tmoz see if it makes any odds.
ANY HELP GUYS IS APPRECIATED somebody must have had the same prob its an ALFA
Something fishy with the pump relay
and put the battery on a loader
1 - 20 of 28 Posts
