Evening all,
Selespeed problem. Mine has started hesitating to change, then jumping two gears, and refusing to go into reverse. A quick check of the oil shows it is off the stick so I assume this is the reason.
Question is, what oil is right? The book says Dexron III but the motor factor says no such thing. Just looks like JCB hydraulic oil to me!
Any thoughts?
Regards,
Andrew
It is a high spec full synthetic ATF fluid.
Just get some Selenia CS Speed fluid from an Alfa or Fiat parts dept or mail order from shop4parts.
