hello what oil do you use for selespeeds gearbox do you top it up from the bottle under bonnet or do it go straight into the gearbox from under the car thanks
The small tank by the wing is for special hydraulic fluid (Selenia CS Speed), it is completely seperate from gear oil.
If you need to check/top-up the gear oil itself (75W90 GL5 spec) then that is via the normal fill plug on the front of the gearbox itself.
