.I have a alfa romeo 147 selespeed 2002 reg autodelta ....60, 000 millage .its had a new actuator fitted a new pump and its been 3 months all of a sudden it jerks on 1st gear or when im reversing somtimes not all the time and when im driving and shift up to go to 2nd there will be a delay on my screen wer the gear selected number will display and somtimes couple of seconds go by it will go to 3rd or when im on 3rd and wana go to 4th it works and when im shifting down somtimes it will just get stuck in gear and all I can feel is a big viberation and ill turn the engine off and disconnect the battrey leads and it starts working again but somtime the viberations realy bad feels like a driveshafts broken type of viberation it feels like that the actuators trying to do its job but it just cant go in to gear it desires and at one point it wasn't going in to gear when the enging was started I can feel and hear a clunking noise it went in gear wen ignition was on MAR so I gave the car a push down the road and selected 1st it went in to gear but the problems gone next day all the above continued and the selespeed pump relay I changed ...in february the SELESPEED ECU was changed last owner who had it it was a used part or could it be CLUTCH because thers so much viberation involved and skipping of gears ..I had it bled, , re calibrated .
Discussion Starter · #2 ·
Its a alfa 147 autodelta turbo conversionAt first it started vibrating on 1st gear take off and delay in selecting gearsAnd then skipping gears and when im coming to a stop down shifting for example from 4th 3rd 2nd and 1st gear I feel the viberation on 1st gear when revs under 2000rpm then on take off on 1st accelerate quick and high so I skip the low revs to avoid juddering it did do it alot when it was realy hot weather regardless of the car being driven ..calibration done bled the system all by alfa specialist and now he has left me with two options maybe CLUTCH or SELESPEED ECU any help asap as irs in the garage waiting for a answer
sounds like a pressure bearing going to break down !!! these things last about 70k miles on a selespeed ....
