1 - 2 of 2 Posts
156 Sportswagon selespeed.
The selespeed will not select any gears. This problem is only intermittant but very annoying when it happens at a junction (or in the carwash!!!!)
50 percent of time it is OK. The fluids are all OK & there is no loss of fluid but the fluid light flashes. If you get out & tap the pump it then works but not a satisfactory solution!!!!. It usually happens after it has gone into neutral but it has also stuck in gear while driving along. The pump seems to take longer when opening the driver door on startup.
Have also tried in city mode but still the same.
either the
* relay for the pump is going bad, swap it with another [ front of battery ]
* the brushes of the pump are worn out & you need a replacment pump [ £30 2nd hand ] or brushes [ £10 ]
* accumulator needs replacing [ £50 }
1 - 2 of 2 Posts
