hi i have a 2004 156 veloce selespeed 2 litre auto can anyone out there tell me how you check the automatic transmition oil level and top it up if its low
many thanks
L
the reservoir is on the same saide as the battery. it should only be checked first thing in the morning when cold & only after the pump has finished priming itself after you open the drivers door. The fluid is Yellow in colour, the name should be on a sticker under the bonnet Tutela SC? the system hold 600mL total. just above the circular plate is the max, which can be confirmed form the dip-stick thats in the cover.
That is for the Selespeed hydraulic system.
For the gearbox oil itself you check like a normal manual box (which is what it is, it isn't an "automatic").
The fill plug is on the front of the box next to the reversing light switch.
