Hi Guys
After 12 months of fixing all the common problems :)
And climbing a steep learning curve.
I have finally had a pump failure.
Replaced brushes in the motor tested OK.
Front seal in the pump front housing leaking......
Removed seal thinking local hydraulic shops would have something that would fit.
Silly move.... Not a standard seal size..... Bearing shops or hydraulic seal manufacturers.
So for all......
If there are Seals available for Actuators and Pumps
If anyone has contact details or willing to advise i will take any information...
Located near Brisbane Australia..
Already sourcing parts from china so location of seals not important at this stage.
DieselBob
Shop4parts are currently selling brand new AR Selespeed pumps for GBP159. See the special offers section.
Thanks for that.
Found a high pressure rotary hydraulic seal that seems to be holding.
Charge times are at 4 seconds with the door and 3 with the ignition.
