Hey sele problems again???
After major leaks from the
gearbox and actuator I decided to open up the box and unit to seal with loctite and changed 6 oil seals in back plate of actuator.
I can only select reverse, when I try 1st there is a loud buzzing sound from the actuator as if it was going to explode but nothing happens... I managed to get it only twice in 1st and second. Changed ev2 and ev3 with no luck.
I can select 3rd 4th or 5th by using the even and odd gears in alfa diag, when I turn it off then on I find it in 3rd and can easily cycle to 5th and back down but drops to N if I try selecting second.
No errors showed up, pressure is between 45-55 bar, clutch rod 28.13
