Hi Ive searched the forum and cant find any info that relates to my problem.Ive got a 2002 147 selespeed.When the car is off I select allthe gears 1 -5 and R.Once the engine is running when I try to select 1st or R the rocks and I hear a clunking sound almost as if it half engaged and then kicked out of gear.It all broke when I arrived home stopped infront of the gate and all of a sudden the car just kept moving forward so I almost hit the gate.braked and put car in N And havent been able to select gears since..Please any info.Thanks in advance
ou will need to get it plugged into alfadiag or fes to see any faults but could just need clutch rod adjustmment,you will still need diag tools though
steve
steve + 1 guessing is no option
the ECU is located in the passenger footwell, although I very much doubt the ECU is your problem, in fact it is the least likely thing to go.
