1 - 2 of 2 Posts
Hi!
I have a bit of an issue - i was cleaning my MiTo today and have inadvertently pushed the little panel with the seatbelt warning lights back into its holder (it's back about 1cm).
I've tried everything I can think of (including tape to pull it back), but can't bring it forward. Does anyone have any ideas how I can pull it back forward (or how to take that assembly apart)?
Thanks!
I saw the windscreen fitters remove the assembly when changing my windscreen.
If you look on the side of the assembly there is a small hole which is designed for you to get a screwdriver in to remove the black plastic panel. I guess there maybe a way to get in to push the screen back forward once this is removed.
1 - 2 of 2 Posts
