No GTV seats to my knowledge have side airbags. The only electrical connection then is the seatbelt buckle connector. You would swap the buckle over to the new seat. If you are going to harnesses then you would presumabley ground the switch so the ECU thinks the seatbelt is always connected.I asked this before but no response: if you fit aftermarket ie sparco, what do you do with the electrics that fasten to the seats for airbag, srs and engine cutout?
There is a steel tube connected to the seat frame that has low voltage electrcal connection. It has some weird connection to throttle (engine cutout?) specialists often advise hard wiring this if you are getting throttle problems. I think someone also mentioned it controlled the srs pre tensioner thing ?No GTV seats to my knowledge have side airbags. The only electrical connection then is the seatbelt buckle connector. You would swap the buckle over to the new seat. If you are going to harnesses then you would presumabley ground the switch so the ECU thinks the seatbelt is always connected.
hi, not too expensive I think!Hi dirka
they look fantastic just the job. Must say they look expensive too
