My new to me spider drove home lovely and is running well. When you start her the oil pressure reading is straight up at twelve o clock. At 60 ish mph it reads at maybe ten to and on warm tickover it's on the mark above the red maybe one notch higher. It runs well and sounds good and the readings are all stable so I am thinking the 25 year old sender may be not all it once was? Do these give problems as a rule? Easy to replace?
Years ago I had a new oil pump fitted to a Saab turbo engine with major miles on the clock and added forty percent to the readings across the board. Is the oil pump replaceable ? Desirable to do? I want to use the car a lot and am just wanting to sort out the basics. Thanks, John.
