I looked in the parts wanted section but it's empty so I thought I'd ask here. I want a few little bits of trim for my car which I suspect will only be available second hand. Is there a breaker that is good in the UK?
Specifically I need the trim panel,vinyl covered which sits on the b pillar and surrounds the pull toggles for the fuel flap and the boot pull. I need the alloy end cap for the top of the drivers side b pillar which is exposed with the roof down. Mine is broken and exposes the steel beneath and the top,of the rubber door seal.
