1 - 11 of 11 Posts
Does anybody know where the RPM sensor is located on an Alfa 147 2.0 twin spark?
I cannot seem to find it on Fiat eper.
Any help?
Hi Ian.
Sorry for not supplying more info. Had a bit of a busy day.
It is actually for a friend of mine with a 147. The car starts and drives. But after a while it just cuts out and wont start again untill it has cooled off a bit.
I ran fiat ecu scan and it gave an RPM sensor error to me. I was actually not sure if it is refering to the crank sensor or rpm sensor. He wants to replace the part.
It is actually for a friend of mine with a 147. The car starts and drives. But after a while it just cuts out and wont start again untill it has cooled off a bit.QUOTE]
I had this same issue. Turned out to be the Crank Angle Sensor. It was supposedly covered in dust. Perhaps a good clean could save some money?
Yes that sounds like the crank angle sensor and it is located on the side of the block.
Cam angle sensor sit behind the outlet cam pulley but they normally age well unless someone damage it with a cam belt change or head removal..
1 - 11 of 11 Posts
