Hello All.
Just got my car back from shop after changing timing belt and removing variator belt/free flow exhaust/among a few other things.
I was pretty confident with the gent working on my car for he has built/raced t.s. engines for many many years.
Question is will removing the balance shaft/variator belt make the car idle more roughly? The car seems to rev and pull happily with no undesirable noises.
A friend in Canada that knows these engines well says no...
And then I have read some say their engine rougher idle after removing.
I am concerned the job may have not been done improperly and would hate to pop my motor!
Thanks so much in advance for input.
First of all why would you remove the balance belt?
The balance shafts remove engine vibration. Have a look here: https://www.alfaowner.com/Forum/engines-ts-jts-jtd-andamp-v6/309402-2-0-ts-balance-shaft-question-2.html#post4513196
And when the workshop changed the timing belt did they use cam locks?
To me it sound like the timing belt could be a tooth off
NB. There is nothing called a variator belt :)
The variator is a device that through an electronic solonoid and oil pressure adjust the inlet cam timing
I didn't have the balance belt put back on when I had the cambelt done on mine. I figured it was one less thing to go wrong on a 190,000 mile engine. Does it run less smoothly without? Maybe at tickover but you would not notice any difference really.
thanks all for any/all input.
when cold started, the engine is actually very quiet and smooth...when its warm/oil pressure ramps up...the diesel type idle appears. I would not suspect this being a product of timing being a tooth off or so or I would think it would be immediate symptom at startup. I'm thinking variator is crapped out or the solenoid is inop. considering smooth/quiet until oil pressure builds up, I'm actually suspecting the solenoid more for it controls the actuation of the variator but I'm just shooting in the dark here. thoughts?
