Hi guys,
My 146ti has a rough idle after a warm start (most of the times)80% and feels like its going to stall, revs drop to 600 and back up and then fluctuates and nose dives some times. I've tried a few IAC valves and its the same. Maf is okay, new plugs, lambda is "alive", radiator, stat, coolant temp sensor is 1 year old. I read it could be fuel related.
Thanks in advance!
Hi guys,
Thanks in advance!
I have had this problem on 2 145's and after changing everything that i thought it could be the only thing that resolved it was a full ecu reset with Fiat multiscan
And it works in the long run or just temporary, Ive tries disconnecting the battery for yhe night and no change...
Could this be related to electrical supply, like a dead alternator or battery, because when there is a bigger load my headlights dim a bit and when I rev it at that moment the lights brighten up again.
