1 - 12 of 12 Posts
I have a 2011 Giulietta 1.4 multiair with 156000kms that started giving me problems about a week ago.
It started off as a small misfire so I changed the spark plugs and put some fuel injector cleaner into the tank thinking that it should be 1 of the 2 that is giving me problems. The car ran well for about 20kms, then I noticed a cloud of white smoke coming from the exhaust.
Thought it might just be the injector cleaner that was burning off so I kept driving. A few minutes later, the engine light came on and I had a massive loss in power. Car started to sound different as well. Luckily I was only about 2kms from home.
Anyone encounter the same or similar problems?
Any sort of help and advice is appreciated.
most likely the multiair unit considering you have a 2011 car. Sometimes the unit can be repaired, most often you need a new one.
White smoke from the exhaust is usually coolant getting into the engine. What are the fault codes?
Will definitely check it out. Haven't had a chance to get my G to the mechanic. Wouldn't there be an unusually loud tappet sound coming from the engine bay if it was the multiair unit?
Thought that as well, however the coolant level is normal. Haven't taken it for a diagnostic test yet.
I'm a bit hesitant to drive the car at all because of the drastic loss of power. Also don't want something else to happen to it.
Sounds like fuel is going straight into the exhaust to me. Either a seriously overfuelling injector or not enough air getting into the cylinder for it to be burned. The later being caused by non opening inlet vales...
Took her to my mechanic. He says that the catalytic converter is blocked. Caused by over fueling.
Hopefully it isn't something major.
Thanks for the help everyone.
Will post updates.
Giulietta 1.4tb Lusso 170 (OU61)
Will post updates.
Hope this gets sorted for you Jude!
Cleared the catalytic converter. Was badly clogged.
The smoke cleared, but the misfire is very bad, car has almost no power and stutters. Almost impossible to keep it in any other gear besides first.
They suspect that fuel injectors 3 and 4 aren't working properly.
Any advice on what I should check or do before removing the injectors?
they are sure the misfires are on cylinders 3 and 4? swap the coils over from 1 and 2, then do the same with the spark plugs to rule out it's an ignition issue. After that swap injectors from good cilinders to bad as i still think it's a multi air issue.
Had all 4 fuel injectors cleaned out and the PCV valve replaced.
Everything seems to be working fine. Hope it stay this way.
Thanks for all the help. Highly appreciated.
1 - 12 of 12 Posts
