My 147 GTA radio has suddenly developed a mind of its own. You can swith off the ignition, get out and lock the car and the radio will sometimes switch itself on after a little while. Needless to say, if this happens after you've walked away from the car and then you don't use it for a couple of days................Hey presto........flat battery.
Anyone had this problem before?
Anyone got any answers? :confused:
Mine did that (it's a GT). Solution I found in other posts was to leave a CD in the player. Does the trick with mine.
Yes, not uncommon fault, and that trick should always fix the issue.
