1 - 20 of 22 Posts
When they resurface the roads and stick the '20mph risk of skidding' signs up, is that a mandatory speed limit or advisory? only ask because they had put them up before they even started / closed the road :confused:
P
Circle - Compulsory
Triangle - Advisory
If it is static (in the ground) then I would imagine it would me Compulsory based on a new road layout.... I could be wrong
If you have an accident and the police believe it was caused by you ignoring the advisory limit they might hit you with a Careless or Reckless driving charge. ;)
I can't remember if it was circled or in a triangle, but defo temp signs placed every few yards and at low level
I only see them when the resurface the roads on the cheap (loose gravel)
Administrator
Some square signs are worth paying attention to.
I passed one of them once on a very long straight highway going up the East side of the Rockies. A few minutes later, an F-15 shot past. :eek:
Pretty sure there must have been an Air Force base nearby, unless their traffic enforcement department had a REALLY big budget!
I thought it meant there was an opportunity ahead? :lol:
S
Or maybe you were driving REALLY fast. :lol:
C
If the speed limit sign has a red ring around it then it's compulsory. If it has a grey / black / white (in the case of the variable speed limit LED jobbies) or no ring around it, then it's advisory. And then there's de-restricted which is different in the way it should be interpreted.
I think the difference is the red ringers are subject to a traffic regulation order where the advisories are not.
That could well be a Scottish thing as I haven't seen those down here.
I usually obey speed limits where there are chippings on the road, as I value my paint and windscreen.
It is when some idiot coming the other way doesn't that gets on my nerves though as I have seen cars windows broken by kicked up stones.
To be fair, I ten to stick to the 20mph limits as it usually means there's liable to be kids playing around the area and I know I would be less than pleased if someone doing more than that were to put any of my kids at risk because of their stupidity. So, feel, if it's mandatory, great and if not, it should be.
The green ringed signs are advisory, the authorities cannot enforce that speed limit and it is still set at the previous red ringed signs.
1 - 20 of 22 Posts
