Hello all
Having just refitted my engine after an unfortunate valve bending incident, I have a couple of quick questions for you masters.
I seem to have lost the wiring connection to the reverse switch,
After refitting the sub frame I am unsure if the wiring for
the the 2 oxygen sensors went above or below the subframe.
The reverse light connection comes from the loom on the nearside chassis leg, most likely been tucked away somewhere, and the 2 lambda cables go above the subframe, through the same gap the gear selector cables pass through iirc.
I’ll have a good look tomorrow.
At least I won’t have to drop the subframe again. Cheers
Im sure the metal brackets that go over the subframe to centre tunnel bolts also has built in clips to hold the lambda wiring, it sort of becomes clear then where they route then, dont forget the side heat shields before you bolt the tunnel up!
