Is it for a 156 or a G ? If it's a G then likely to be broken cables in the 2 tailgate rubber sleeves at the top. If not that then possible bad earth, worth looking for.Hello guys
My right reverse light has stopped working and its not the bulb.
Are there anyone who Can help?![]()
Yep, had exactly the same, 3 black wires on mine snapped - earth to lights, rear window demister, and ariel cable (not sure why this was there as it was not going to the ariel actually).Thank you for the link.
Found out that three wires hidden behind the rubber from the tailgate to the body had snapped.
I cut the wires and welded them together.
I Can see that this problem is the same as all the other G's.
