1 - 20 of 24 Posts
Greetings erom rainey Ireland
Like the rest of you my rev counter was very intermittent.this is how i fixed it.Undo the 2 3mm allen nuts that hold in the instrument panel.The cowling and inst panel now slide forward and out.pull it foreward and twist it gently around so that you can see the back of it .You will see a yellow coloured board with about 11 small nuts they are 5.5mm.Very very very gently turn them each a quarter turn.Only the 3 nuts behind the rev are for the rev but you may as well tighten them all.I cant emphasise enough to be carefull the board is very delicate.Be interesting to see if this cures the other cars.Best of luck.
Alan
Keep her clean
Hi wrinx sorry bout that,
bit new to this computer lark ive put a post in the tech lounge to explain.
Alan
Keep her clean
Discussion Starter · #7 ·
Thanks Joe ,
These fellas on the big island are always giving out. Only joking wrinx.
Alan
Keep her clean
Discussion Starter · #8 ·
thought i'd move this for you wink
(also removed the other one talking about this one.. thought i'd save you from some flak)
:D
rgrds
j
Discussion Starter · #10 ·
look sonny(wrinx),
i'm here to ensure u get all the flak and to ensure 'normal' people get away with everything :D :D
isn't that right fasud55
j
i too did this a while ago to try and remedy something else but did not realise that since then it has not happened sorry would have posted a while ago.
Discussion Starter · #18 ·
Just done this on my 1997 155, works a treat, REV Counter working continuosly for 2 days now !!
Discussion Starter · #19 ·
Wierd that its all the 1997 models!!
Mine has started to stick a little when accelerating.......unless its 'cos the car accelerates quicker than the needle can move wink
wrinx
Discussion Starter · #20 ·
Hi Guys,
interesting one that such a simple thing cures an annoying problem. Pity that Mangoletsi didn't think of it when I had the same complaint. Instead, they replaced the whole intrument binnacle [I also had the yellow fuel warning light coming on when it was nowhere near low] at a cost of £400. Luckily was still under warranty!
regards
Raj
1 - 20 of 24 Posts
