I
Is it possible to reset ECU without disconnecting battery. Simply by removing it's fuse for some time?
J
Discussion Starter #2
don't think so.
You could of course open up the ecu and take out the wee chip. Put it back in after 5 mins or so.. that should re-set it too.
less risky way would be to disconnect the battery tho.
j
J
Why take out the chip? This is much more work than just unplugging the whole metal bin in wich the stuff is lokated. Just unplug the big plug and after some time replug it. 5 minutes would be okay i think. And no risk of bending the chips contacts.
Jan.
