Hello folks,
I am trying to replace the front seat belts on my 159. I searched the site and found similar posts but I am having some difficulty.
I have unscrewed the upper nut attaching the B pillar cover, I then used a car tool to pop the 2 catches at the top and loosen the cover. The problem I am having is that I cannot separate the top portion of the cover from the bottom. Try as I might it won't pull out. I can see 2 white plastic (clips?) which seem to be the problem but I cannot access them.
From the picture found online of the part in question, you can see the 2 clips and beside them are 2 flat areas with holes in them. Are those holes for screws/nuts and is that what is holding the piece in?
Your help on this is appreciated.
