Can anyone give some advice. I have just fitted some replacement front seats to my 156.
Now when I had only the driver seat in I had to move the car with out the passenger seat in place.
I have now fitted the passenger seat and the red airbag light stays on.
Before removing and fitting these seats the airbag light was not on.
Have I bought seats with a faulty airbag or is the issue there because I turned the ignition on when one of the seat was removed.
Can I clear by disconnecting the battery.
Any advice much appreciated.
Thanks.
Wayne
Unplugging any of the airbag components without disconnecting the battery for ~1/2 an hour will cause a fault to be registered.
It needs to be reset. You can do it with AlfaDiag, or take it to a dealer
AlfaDiag Alfa Romeo Diagnostic Software ... you'll also need a modified KKL cable, you can either buy one from ebay for about £8 and get your soldering iron out ... or rarebear (on here) can sell you a pre-modded one (for quite a lot more than £8)
