My flexi has a hole in it so is blowing like mad and causing the motor control system light to come on and say the lambda sensors are failing (changed these a few months ago) and also make the engine noisy as hell.
I managed to source a front cat for my 147 from a breakers instead of paying the £££'s I was quoted by the garage, also I have decided to fit it myself as it looks quite straight forward, but thought I'd ask you guys first!
So any tips? Should I do it after going for a drive, once its cooled enough to touch?
I have the metal gaskets and also some exhaust assembly paste, all the right tools and will be doing it up on some ramps with the father-in-law.
Is it as straight forward as it looks?
