This weekend, I’ll hopefully be replacing a leaking hydraulic hose on the Spider roof. In theory, I just need to undo both ends, re-assemble in reverse order, top up the fluid and enjoy a fully functioning roof once more. But being an Alfa, I’m guessing it won’t be that simple. Any hints or tips on how to do it would be much appreciated. Many thanks.
hi all, my 98 ts spider has sprung a leak in a hydraulic hose which i need to replace. how do we disconnect the hoses at the pump end. i've turned and turned it and it doesn't unscrew, i've tried pulling and it won't pull off. so, what's the trick. cheers robert
www.alfaowner.com
The ram end I’m quite happy about; I know it comes off because I replaced the ram before realising that the hose was leaking. For the other end in simple terms; loosen or totally undo the motor retaining bolts? Undo the 4 bolts to release the plate that the pipes all go into. Remove circlip and remove hose? Is it just a conventional horseshoe type? Do you need any sealer when re-assembling?
Sorry for all the questions and thanks again for your help.
My memory says loosen the face plate that all the hoses go into and you'll get them off easily. I removed the face plate when I did it because I replaced all the hoses and it was easier. I didn't use any sealant. There are "o" rings on each hose - don't loose them.
Related Threads
Alfa Romeo Forum
7.1M posts
216.5K members
Since 2001
