It should be, but late 2000 was the changeover for the CF3 engines if I remember right.
You may need to swap over a few things like the plenum chamber.
If you have a picture of the engine, the CF3 has a large connector and the ECU attached to the plenum chamber near the throttle body. The CF2 doesn't have this.
There may also be sensor issues and the exhausts are different, but they should still swap over.
