And was wondering should the 2 rubber sit 2 on top of the wishbone or 1 on top 1 on the bottom of the wishbone?
Last rubber was so perished i dont know if it got squashed through the wishbone or not.
and should i put any grease on or will it make any difference on the powerflex?
got the old ones out already just waiting for confirmation.
done, quite easy once you understand the mechanism between both sides.
Tip: do 1 thing on right hand side.. then do the same thing on the left handed side.. go back and forth.
once you aligned up everything, you take a 25mm wrench or a breaker bar and a jack and use the tie rod as the pivot between the jack and the Drop link to push it down and then tighten it up.
the top nut tells me when its done tightening but not the bottom one. did i over tightened the nut on the bottom too much.. or is it ok?
