hi all,
i have started to get a droning noise from the rear axle and upon investigating looks like i need to replace the rear wheel bearing on the passenger side.
So i did a bit of digging on the Web and came across this YouTube video which makes it look so simple .
Now i have 2 questions
1. is it really this easy and if not what are any gottas i should prepare myself for ?.
2. would it be wise to replace both rear wheel bearings as i'am going to be replacing the disks and pads any way ?
thanks in advance and love been back in my Alfa again
brendan
I did the rear wheel bearing a while ago on my GT and it was pretty straightforward. My mine concern was pulling the inner race off and got a pulled to be prepared for this, but didn’t need them as the race just came off by hand. You will need a torque wrench that will go high enough - I had to buy a new one from Halfords.
Good luck!
Administrator
GT 2.0 JTS 2007
The bottom bolt is the main problem in doing this job.
Now that many of our cars are owned by people who need to keep costs down and do things themselves, it may be good to have a video like this as a sticky.
As Chris M stated, sometimes the bearing assembly just slides off. I had a 156 which the bearing was really hard to remove. I had to use a slide hammer and then an angle grinder, then a hammer and chisel to split the inner bearing race. The new bearing was clearly going to be similarly really tight (hence why the last bearings only lasted just over a year) so I gently dressed the stub axle with a flap disc on the angle grinder to the point it only needed gently tapped on with a hammer. That eliminated yet another premature failure.
