1 - 10 of 10 Posts
I know this has been covered a few times and i know a few have removed the cat and still pass mot.. But I've just found this and now this has put me off removing mine as was going to go straight from downpipe from turbo
See pic 1st item!
Just keep your main cat and refit for mot,can swap mine out in about 30 minutes if needed, pre cat will not get seen so won't be checked.
So buy decat front turbo pipe and centre and refit centre as when is needed?
That'll do it.
The front downpipe is almost completely hidden behind heat shields and under-trays, so the tester will more than likely not get eyes on it...
Even if they do see it, they'd still have to know this car came with 2 cats from the factory... as the main cat in the centre pipe is bleeding obvious!
That'll do it.
This the process i will take
Comw service time I am planning on removing the cat from the turbo as well. As other have stated it is pretty much impossible to see that area with the undertray and heatshield in place.
This is exactly what I'm doing after mot in February
But i'm removing all cats and backbox
1 - 10 of 10 Posts
