Hiya,
So I'm trying to remove the rocker cover, as I believe I need to change the gasket due to a slight leakage of oil just by the dipstick.
I'm trying to workout how to undo the bolt which is on the far left, hidden behind the bracket. Do I need to take the cambelt cover off to access this?
Additionally, having removed the cover with 'Alfa Romeo' written on it, I tidied up around the coil packs (investigating really). As I'd undone everything else to try and remove the rocker cover, I think I may have dislodged the gasket, thus causing this small oil leak, I'm not sure how likely this is? After putting everything back, the car makes a chugging noise and I think it may be slightly down on power. I've made sure the spark plugs weren't over tightened, and found the left plug had a bit of oil on it but not much in the socket other than that.
What would you suggest as the next thing to try, given that these are the only things I touched and it was fine before hand! Typical person taking something apart and it not working properly afterward scenario!
aperbag:
All help is much appreciated, thanks :thumbup:
