1 - 10 of 10 Posts
P
MY GTV has got tinted windows i'm afraid to say! Not black, but like a dark smoke effect. I have decided that I want to remove this as I think it looks pants...
It has been professionally applied I would imagine as it's perfect, no bubbles or nicks in it.
I have asked a few people about this already and they have tried to convince me to leave it as it's a nightmare to remove as it's glued onto the glass???!
Has anyone attempted this? I can see this taking me hours of picking and scratching!
There must be an easy way!!! :rolleyes:
Depends very much how the tinted film (or whatever it's called) is attached...
I once helped a friend to remove tints from the back windows and it was pain in the a**, because the film was "sticker"-kind and the clue was left on the glass :eek: :eek:
I'd say you'd have to be bloody careful of the heating elements on the rear window. Could you heat it up with a hairdryer or something and then try peel or scrape it off??
Thank god I wasn't around anymore when they started to take the rear window tint off :eek:
I only helped with the back side windows :eek:
P
I'm having second thoughts, but I don't want it on there. :mad:
I heard somewhere that spraying on undiluted ammonia helps disolve the glue? Sounds a bit dangerous to me...
I might just break all the windows and tell the insurance it was vandalised! :D
Nope, don't go down that route. It will destroy the interior.
B
;) Try phoning someone like South Coast Tints in Southampton,they should know how to get the stuff off,I believe most tinting firms also offer a de-tinting service.........might be easier that way :p
P
Well, sat in traffic last night, I began to pick at the edge of the tint of the drivers side window.... you can guess what happened next! :rolleyes: I was pulling off the tint in big sheets! :D All I have left to do now is the rear window.
The tint has left a sticky residue on the windows, but i'm sure some white spirit / glass cleaner / elbow grease could get it off!
C
all you need is some washing up liquid in hot water and a scourer, plus a bit of work....gets the glue off no problem :D
1 - 10 of 10 Posts
