can anyone help!
I am doing my cambelt 2.5 litre 24v and cant seem to be able to get at the wire injector clips . the ones on the coil were easy to get and remove but the injector clips seem to be positioned in such a way that It looks like removal of the fuel rail to be the only way!
can anyone help?
rgds
If they are the same set up as the Twinspark you just pull them off. They fooled me too as the other plugs you have to pull the metal clip but on these you don't.
you will see a small section of metal on these clips.
PUSH that INWARDS witha flat headed screw driver & then gently pull the connector off.
if you pull without pushing in the clip you'll damage the connector
I didn't damage mine. I will have to check (when it stops raining) but I spent ages trying to work out how to do it, pushing and pulling the metal clip to no avail and in the end, just pulled!
thanks guys as usual a great bunch of people offering their help........very much appreciated
