In my on going saga of strip down, I attempted to remove Alternator as the pulley seized causing this nightmare.
First, Removed the power steering pulley relatively easily, removed the Air Con pulley and thought I was on home straight and removed the short bolt on Alt. Then spent all afternoon trying to remove long bolt on alternator without success. :(
Have removed engine mount on belt side, tried lifting engine on trolley jack, tried lowering engine on jack, tried tilting engine back by jacking front of engine but I'm stumped, I am achingly close to the big gap of the wheel arch but might as well be a mile away. I can't get the long Alternator bolt out as it comes as far as chassis and I'm stuck!
So, someone please tell me it's something simple that I need to do as at the moment, I'm contemplating unbolting subframe and the other thought is should I unbolt the three pulley mounts on the front left of the engine? Please tell me this is an easier job than I'm thinking as I'm currently stumped!? :(
Have you tried the car on axle stands at the front (maybe 2nd or highest setting) and then lowering the engine...this gives the engine a bit further to travel down, watch out for pipes getting crushed against the subframe. You can see these pipes with the belt side wheel off. I had trouble with the engine mount and this resolved it.
Hi Raz,
I tried dropping the engine as far as it would go but the subframe prevents it going any further.
Surely, you don't have to remove subframe to change the alternator!?
Just had a quick google and came up with this thread... does not look fun
Worse job on a 159 my indy said. When mine was being replaced, the bumper and everything behind it was out, for some other work.
Thanks Stuart but alas that doesn't solve my issue as that fella got his mechanic to do it.
BigJim, it is a pig of a job, I have bumper, radiator, fans, air induction off and I think I have two choices,
1.) Remove the bracket that bolts to engine and all three pulleys are bolted to. I had a go at cracking one of the bolts earlier but I think I need to eat more spinach.
2.) Undo/loosen the two bolts on subframe each side front, loosen the strap bolt from wheel arch to subframe and loosen the 4 bolts on the rear of subframe (2 each side) This I hope will let subframe hang a few extra inches and facilitate the engine to go low enough to reveal bolt gap in wheel arch?
* Then with subframe lowered I can remove sump to see if I can locate the 11 missing needle bearings from my rockers that exploded.
