Hi
How do I remove the front left A pillar trim.
It has an airbag symbol on it, so I assume I can't just yank it off.
I'm trying to cure a bloody annoying rattle !!!!
Hello,
So forwards towards the windscreen, then undo a screw. Then I should see the air bag and a few wires???
pull the trim forward to release the clips can be tight.The trim is held on my a strap and a 5mm allen key bolt hope that helps
EXACTLY the right answer..
just pulls off, then there is a nylon strip held onto the body work by a 5mm allen key.
all off and ready for me to check that this is the rattle.....
if it is the cause, i will line it with some stick on felt !!!!
i always get my cars to run silently !!!!!! them sell them :(
I need to remove the same cover to install my SmartNav.
Is there a chance of the airbag going off?
Would it be wise to disconnect the battery for 15 mins beforehand?
hi
no chance.
i found it to be the same as any other A pillar cover, i have removed.
its just a plastic cover that you pull off..there is no air bag device under it.. it looked to me like the airbag was in the head lining...or not even there !!!!
just pull it off, you will need an allen key to undo a strap, that is under neath the cover. but you will see that when u pull it off.
