1 - 2 of 2 Posts
My passenger side electric window hardly moves when i press the button! thought i should remove the door card and put some grease on the runners.
any tips on removing the door card? as i know there are probably lots of hidden screws! thanks for any help.
Fairly straightforward to remove, more fiddly to replace because of aligning the door handle screws relative to the window switch unit! If you don't fit the screw in the right sequence then the switch unit won't sit flush and can sink into the arm rest.
I don't think any of the screws are that hidden. If the internal plastic panel clips don't want to release then odds are you've missed a screw!
Try searching the forum because I know this has been discussed before (certainly by me in relation to door handle replacement!).
1 - 2 of 2 Posts
