I removed my air box today to fix sheared off bolt as it was not air tight. Got it all sorted but can't get the airbox back in. I can't seem to get the knob at the bottom (ooh err) to fit into the hole of the bracket and in the top as well. Is there a knack to this? Can I remove the housing bracket and fit the air box on then put it back as a whole? Your advices would e appreciated. Thanks. Gtv Cup 3.0 by the way.
Got the airbox refitted. Took the housing off and fitted back as a whole. All gaps sealed. Cleaned the maf sensor (prob a temp fix) and went for a blast. No hesitation etc but still monitoring. Fingers very crossed. Anyone noticed change in acceleration over bumps?
Mine does that, catches me out sometimes. if you do a search on here there is a post telling you how to cure it. its the throttle pot sensor that needs re soldering.
