Hie guys can someone tell me how I can refill the gear box oil. The car had been parked coz of a gear lock problem now went to check it the gear box oil tank is empty. How can I refill it making sure I do not trap air (causing an air lock). Gear box kit does it come with the pump?:confused:
It sounds like you are talking about "Selespeed Fluid", not gearoil.
Completely different fluids inserted into completely different places.
The Selespeed tank takes Selespeed fluid, get some Selenia "CS Speed" from your local Alfa/Fiat parts dept. It takes 0.6L in total, but comes in 1L containers.
The gearbox uses 75W90 GL5 spec full synthetic gearoil, it takes 2L in total.
Don't get the two confused.
Thanks man am not technical and will be having someone look at it on Friday. Will let you know of the developments.
