:confused: Does anyone know where the air-con reciever-drier hangs out on a 2002 2.4JTD?
told you should change it when you renew the (noisy) compressor! found some Delphi ones on ebay but can't find anything looking like them on my car. Could it be in that tube with plastic cap on passenger side of condenser? theres a pressure warninf label on it
If its like the other models its behind the bumper drivers side just above the power steering cooler coil :thumbs:
Assuming it's the same as a petrol one, take out the offside foglamp and lower grille and you can see it.
Hope you found it if not follow the pipework back from the compressor it's between the bottom of the compressor and the black coiled pipe work .
Discussion Starter · #7 ·
No - couldn't see it!! Not now convinced its the air-con compressor thats at fault, a mechanic heard it running today and said that noise sounds like the dual mass flywheel to me - is you belt tensioner juddering? well yes it is!:eek:
The JTD seem to have a bit of a issue with these they need setting carefully when replacing.they will chew the belt up if not set properly.
The receiver is there it's a alloy canister about 20/25cm long bolted to a bracket with the pipes clamped to the top .
