Rebuilding a 176k mile engine - condition, what to change and where to get it?
14K views 76 replies 14 participants last post by  lphuk
#1 ·
The engine for my Stratos project is finally in bits and has been checked over before the rebuild. Overall it's in amazing condition considering the mileage.
You can still see the honing marks on the bores!!
Crank and camshafts all fine too, no scoring or wear.
One of the heads is a darker colour (inside) than the other. Engine builder not sure why and never seen mismatching colours on twin head engine but perhaps one was replaced at some point?
One small issue. Whoever did work on the engine before (we think maybe the rocker covers and / or sump have been off before) used a *bit* too much sealant and the surplus found its way into the sump. About 70% of the pickup area of the pump was covered!
So - these engines seem very very strong and well made.
The guy building my engine then called a mate of his that builds Alfa race engnies and had a chat. He said the liners and pistons would be good for another 170k as they never wear out. So we've got a list of things we are thinking of replacing. On the list are a few things that seem like a good idea but when you add up the costs they get mad expensive - bloody 24 valves.
I'm only going to do this once and (like me) the engine builder is a stickler for doing stuff right and he's suggested changing just about everything. So this is a list above and beyond what I would have expected:
Valves - why not re-lap them? £360 a set
Valve springs - I can't seem to find a source for these - can anyone point me in the right direction?
Valve guides - £115 happy to change these.
Cam followers - £245 - worth changing?
Also want to replace the oil pump - where can I get one and what do they cost? Can't find anything online.
I'm going to have it balanced and also fit ITBs. Does anyone now if you can fit Jenvey's ETA2 electronic actuator to the Alfa V6 - is there room?
Cheers for any advice and info anyone can supply.
See less See more
#2 ·
The highest mileage one I've been into was 137k and the inlet valves were like new. I felt I was wasting my time lapping them, let alone replacing them. Exhausts needed lapping, but not replacement. Cams and followers were fine.
What do you plan on doing with the car?
If you're going for bonkers power and going racing, I'd be more picky about replacing stuff - but I'd probably be starting on the bottom end with new pistons and liners, I know they look fine, and would be fine on a road car....but racing is a bit tougher on stuff.
If you're not going racing, and leaving it standard, I'd just grind the valves, check to oil pump to spec and put it back together. You're not going to be using a Stratos as a daily driver (if you are, you've got bigger balls than me...), so it isn't exactly going to rack up huge mileage. I found zero slop in the valve guides at 137k, no point in changing them at all.
#4 ·
Very easy to catch the pickup with the side of the sump when offering it up
I will be very interested in the answers. Sometime in the future my son and I will be rebuilding his 3.0 12v engine for his spider ;)
#5 ·
Thanks guys. Just looking for a fast weekend road car. No racing, and it won't get lots and lots of use on the road either.
Builder has said we'll get the heads in bits and see if we need valves or not. Possible just lap them in as suggested. We plan to hone the bores and use a new set of rings.
He's adamant about an oil pump. Problem is trying to find one. List price is about £320 :wow: and not sure if they are available. The drive gear (2 cogs and a chain) that works off the crank is no longer available but would have been £400 if it was. Waiting to hear back from a parts place on the pump.
Springs are about £12 a pair (2 springs per valve).
Cams will be going to piper for a regrind.
Seems like skimming the heads is recommended too with the cams and ITBs. maybe a 1mm skim to raise the CR to about 11:1. What's the valve/piston clearance like once 1mm has been taken off?
#8 ·
Erm......lots!
If I replace everything (except pistons and liners) and put ITBs on then it will be just over £6k with a clutch and solid flywheel. But that is just about everything including coils, alternator, starter motor, air con pump, water pump, all belts and idlers etc. and includes labour costs for the build as I'm not doing it myself.
Would be cheaper to buy this - take the engine out and sell the rest as parts :ermm:
http://www.ebay.co.uk/itm/2000-V-Al...257831?hash=item35fede7267:g:Y-wAAOSwiylXCmwl
If we just lap in the valves and the cam followers are OK along with some other bits then it might be £1k cheaper.
This is my first experience with Alfa engines and so far it's looking like as expensive one!
#9 ·
It's been a while since I last posted.......just short of a year in fact!
Right! I finally have an engine!!!!!!
Collected it today. Crap photos as I've just bunged in on the floor in the garage in front of the chassis (Stratos). Will take some proper ones once I get it moved.
https://c1.staticflickr.com/5/4258/35142812976_34c10c7424_c.jpg
https://c1.staticflickr.com/5/4254/35182754095_96c3c79fdb_c.jpg
https://c1.staticflickr.com/5/4279/34796398010_da7791ab83_c.jpg
https://c1.staticflickr.com/5/4225/34796402890_cdfa291d3f_c.jpg
https://c1.staticflickr.com/5/4220/34373602883_d502a532c5_c.jpg
https://c1.staticflickr.com/5/4245/35142815516_e5afbf2853_c.jpg[
Here's what's been done:
Complete strip down
Degrease, clean, wash vapour blast block, heads, sump cam covers etc etc. Clean and decrease all internals and check for wear.
Hone bores (no wear so no need to re-bore)
New mains, thrusts and big ends
New piston rings
Full new engine gasket set
Full new cambelt kit with all new pullies, idlers and tensioner
New water pump (metal impeller)
Re-manufactured replacement starter motor
Re-manufactured replacement aircon pump
Re-manufactured replacement alternator
Re-manufactured replacement oil pump
New thermostat and housing
New crank pulley
New aux drive belt
New Alfa GTA clutch kit
New 6.5 kg lightweight solid flywheel custom made by TTV
Mill heads 1.2mm to raise compression to 11.2:1
Valves reground
Piper reground cams (slightly more list and more duration than standard)
New hydraulic tappets
New uprated valve springs
Custom made valve spring caps (as OE ones wouldn't fit the uprated springs even though they should have!)
All bolted back together once the whole bottom end was dynamically balanced by Andrews Precision.
Uprated on-plug coils (Audi units) and required connectors
New sensors:
Cam
Crank
Knock (x2)
Bosch LSU 4.9 Lambda and LSU 4.9 connector
Water Temp
Reverse switch
Oil pressure switch
New OE Lower Cam belt covers
New OE Upper cam belt covers
New OE Cambelt cover
m7 stainless cap heads (x22) plus washers
Fumoto Drain Valve
New oil filter
New platinum spark plugs
Just waiting to take delivery of the custom CNC machined ITB manifolds form and the gearbox back from rebuild and I can dry fit in the chassis and run the oil cooler and fuel lines etc.
Dry fit will also check the exhaust fit and once happy the manifolds will go for performance white Zircotec ceramic coating.
Total cost?
Erm...............let's just say fu**ing mad. Parts alone for the engine (forget the gearbox, ITBs, balancing etc.) was about £3300.
#16 ·
My 2.5 at 70k, had bores that looked like new - you could see the cross - hatch (If that is the expression) Don't forget to de-glaze the bores, they may not be bad but it helps lubricating oil stick and when bedding in your new rings, any glaze is harder than you rings are. Definitely do the guides, but re-lap the valves - if they aren't bad. Thus, neither will the seats. Oil Pump - Talk to E.B. Spares. Cam followers - if slightly scuffed, why bother. The important thing is the condition of your cam lobes.
Springs - get them tested, but then again talk to E.B.
Disparity of head colour - A sign of heat disparity between heads. Try to improve the temperature balance between banks - you'll gain a couple of brake horse.
But if you are serious - do as your mechanic suggests - the lot. Slow down and spread the cost.
#17 ·
Sorry for the silence - bit of an update.
Trumpet tray made
ITB levers all done (3D printed metal)
DBW actuator fitted and Linkages setup
Trumpet tray powder coated
Then I made an airfilter housing to fit a K&N off the shelf unit
Base (need t add 2 more spacer posts):
Add filter
Put lid on
Fit to car!
A bit of zircotec ceramic bling!
Oil catch tank for breathers on each cam cover
ECU
Just got the oil cooler to finish off and then it's away for a custom engine loom and starting it for the first time!
#19 ·
Just beautiful. Some great work.
Do you know the part numbers of the coils? I have been looking at upgrading my coils too. Thanks,
  • Like
Reactions: Ralf S.
#24 ·
Right....it lives. Sort of :depressed: I would welcome some views on this
This was the first start, completely from scratch without a base map. So it was never going to be a super smooth start. However....
As you can hear there is a very load ticking noise. It's not from the tappets, oil pressure is spot on - well over 5 bar cold. Engine itself sounds sweet otherwise. Sounded like it was coming from the crank pulley. So removed the aux belt to eliminate the Alternator, water pump and AC compressor.
Now, this sort of sounds like a spun bearing but doesn't sound like it's coming form 'inside' the engine. It's a totally rebuilt engine and has never been started before. The noise was there from the moment it started. So (although not completely impossible) is very, very unlikely. It's not catching on the cam belt covers.
It doesn't make the noise at turnover.
I've not broken down in tears yet.....
Does anyone have any suggestions as to what this might be? I really, really don't want to have to remove the engine and pull it to bits if I really don't have to :(
#25 · (Edited)
https://www.youtube.com/watch?v=PYFhzfQ98u4
https://www.youtube.com/watch?v=qJz6XgVzrSQ
https://www.youtube.com/watch?v=MaJg5YtLqQw
It sounds constant, so it is not rev related, so it's not mechanical - I don't think. To me, it sounds electrical. Fuel pump?
I've always had a similar "Tick" on my 3.0 GTV, slightly lower level. Never been a problem. I often wondered may be a fuel pressure relief valve or something. But has never caused any problems. If it was mechanical, it wouldn't be constant so I think you can rule out the engine.
#30 ·
All wired up now and running (at idle at least) will get fully mapped once the body has been fitted. Wiring / mapping chap is away form mid Nov until Jan so thta gives me time to get the body sorted and maybe get the car painted.
When we started it up we got another horrible noise......turned ot it was the back of the cam belt covers rubbing against the cam pulleys. I was missing this bracket! Alfa Romeo V6 (Busso) Cam Belt Cover Bracket - OEM P/N 60608831 (60608831) :: TotallyAlfa
Didn't even realise there was supposed to be a bracket sthere to be honest. Ordered from the Totally Alfa website, arrived very quickly, fits great and stopped the noise.
Final brackets for wiring harness. Injector harness connector:
Knock sensor and cam sensor
Fitted lots of dynamat type material in the cabin area
Fitted the air filter as the ITBs are now balanced (at idle)
And now it's back at Lister Bells workshop rad for body fit. Only took 2 yrs and 8 months from first collection the initial parts of the kit :ermm:
They'll be putting bits like this on it:
And making it look a lot more like this :driving:
#32 · (Edited)
Cheers. I guess you could always put a 'bump' in the bonnet :rofl: Lister Bell have developed a really nice setup that used the full ITB setup from the E46 BMW M3, looks really nice, but again it wouldn't fit under an Alfa bonnet.
I was going for something like this
But I'm starting to think this might be cooler (A Startos can carry off a bonkers colour combination.)
#33 ·
I like both but prefer the red in my old age... think its really looks great against the gold alloys .. and its shiny but that could just be the picture's lol..
i,m ok using a custom made set up using bike bodies from a truimph triple but still developing it as times allows so slow going. need to travel to find cheaper laser cutters lol
