This is mainly for Rich Shaw.
If you try to fit a rear undertray (fuel tank guard) as fitted to earlier models / V6's you need different fuel tank straps as later models don't have the bracket on them that the guard bolts to! These are about £5 each I think.
The bolts for holdig this on are parts:
Front fitting onto fuel strap
2 x 0011612624 = 40p
2 x 0007628401 = £1.76
Rear clips onto bumper
6 x 0060806161 Flat washer = £3.36
6 x 0060809710 Screw = £0.54
Not sure on the fuel straps, but I think they changed after July 96.
Why do Alfa make it so difficult!!
Henry,
Pease tell me, what is the aerodynamic purpose of this underwing that you are taliking about? Is it for a handling or top speed advantage?
Regards
Jacques
The V6's have them as standard and Henry's just trying to work his way up to one wink
Seriously, I think it's supposed to smooth the airflow underneath the car.........it will also protect the underside from all that nasty dirt and mud :D
wrinx
The smoother you have the airflow under the car, the better handling you have in theory. If you lower the car and have a smooth bottom (lol!) then the air will flow faster and generate a vaccum which inturn creates downforce.
The reason I was fitting it is becasue it cost me £10 brand new!! Bolts were £8 and the fuel tank straps will cost me £10! The whole thing will be £28 for something you can't see!!!! Why bother! It might keep some crap out from the lower chassis and protect the tank from stones like Wrinx said. V6's don't come with a front protective guard as the engines are too heavy, so any extra weight would make the handling even worse that it is already with its sloooooooowwwwwww steering rack!! wink
My car has the rear undertray, so I polish it every Sunday !!!
One advantage of the tray I found when one of the fuel tank straps snapped at the last "Scottish Meet" is that it kinda helped keep the fuel tank off the deck until I got the straps replaced. They were about £5 each and I painted them with Hammerite so they hopefully wont rust and snap again. It took 2 hours to replace the straps 'cos all the bolts that hold the tray on (about a million of them) were seized.
It also would have been impossible to change the straps had the car not been on a lift. My mini mate actually squeezed himself inbetween the tray and underside of the car to remove a couple of bolts at the end of the straps (we gave up on removing the tray as the bolts were just turning and turning and turning.....).
Marlon
HI HENRY !
IS THE FUEL TANK GUARD N° 60603796 MAYBE ?
BECAUSE I WANT TO IMPORT ONE FRON ARGENTINA BUT I´M NOT SURE ABOUT THE SPARE NUMBER.
AND YOU SAY THAT IT IS NECESSARY TO ASK FOR THE BOLTS AND CLIPS ALSO ?
CHEERS
Discussion Starter · #7 ·
Sounds like the right number Jorge. Check your fueld tank straps first to see if they have angled brackets on them that it can bolt into. I only got mine because it was cheap!
i lost my rear undertray when i hit a large puddle at speed. It acted like a huge scope , and was ripped off, the rear bumper was also damaged.
I havent replaced the undertray yet, as i wasn't sure of the cost , bound to be expensive........it is an Alfa!!!!!
