Can anyone tell me if the rear springs on the v6 and the twinny are the same or different. Also are shop 4 parts a good place to buy from or any other places.....many thanks. ..Steve.
Do the bushes need replacing? Maybe using powerflex? If you are changing the springs, what about the shocks. Bump stops sometimes need doing too. But firstly i'd check the rear bushes as its a known weak point of the car.Suplex springs have been ordered.....now to acquire all the other bits for a suspension refurbishment. ....anything else I should replace/refurb while I at it.....any advice gratefully accepted.
What is the firmness like of the suplex? I need new springs. I am very keen not to get anything harder than original though - the ride is bad enough as it isI will second that. TS and V6 springs are different. I found out the hard way. Suplex gave me the correct ride height and comfort to my V6.
Suplex is very comfortable, Eibachs are much harder, had these on another car...What is the firmness like of the suplex? I need new springs. I am very keen not to get anything harder than original though - the ride is bad enough as it isI will second that. TS and V6 springs are different. I found out the hard way. Suplex gave me the correct ride height and comfort to my V6.
I've just spent another £2k for a complete front to back replacement of all suspension parts and Koni dampers.It's a keeper alright..intending to do as you have pj3074 as well as new disc's, pads,Goodrich lines and refurb calipers if the funds allow it all depends on how much my mechanic charges me!!
