Hello,
Just a query. After chatting to a friend who was able to enable various settings on his A5 via his OBD port I had a dig around this morning on MES.
Now I found a setting in the Can Setup were you can enable the parking sensor display. I realise there is an advice that it may not be available on some vehicles but as the option to enable was there I assume, wrongly probably, that mine was not one it was not available on. I followed the procedure and enabled the setting but it doesn't seem to work.
There is advice to execute the PROXI Alignment procedure but were can you do this. I can't seem to the option to do this.
Cheers for any advice.
